Throwing shade on the Moon
The May 2022 total lunar eclipse may be the darkest since that of Dec. 9/10, 1992, which occurred after the powerful 1991 Mount Pinatubo eruption in the Philippines. On the Danjon scale of brightness and color (from L = 0 to 4, with 0 being the darkest and least colorful), the December 1992 totality had a Danjon value of L = 0.5 to 1.0. For the May 2022 event, David Levy of Vail, Arizona, estimated a Danjon value of L = 1.5. Harvard University astronomer Dan Green, observing in St. Louis, Missouri, found the eclipse at mid-totality to be about magnitude –1.5 (or roughly as bright as Sirius) — quite the drop from the Full Moon’s magnitude of –12.8.
May’s particularly dark totality was caused by the Moon’s passage through the southern half of Earth’s shadow, where refracted sunlight was dimmed by aerosols injected into the stratosphere by the January 2022 Hunga Tonga-Hunga Ha‘apai eruption. The dimming effect could be spied during the penumbral phases, when it was only 36 percent eclipsed; usually it is first detected when the Moon is about 60 percent eclipsed.
During the umbral phases, a nearly uniform burnt sienna color washed over the Moon’s face with little other color noticeable. Through a telescope, the umbra’s leading edge appeared steel blue almost throughout the entire umbral phases; this effect is due to light passing through Earth’s upper stratosphere and penetrating the ozone layer, which absorbs red light — thus making that section of the shadow appear blue.
Come totality, however, the Moon’s extreme southern limb (that farthest away from the umbra’s center) glowed the color of straw under a setting Sun, while the Moon’s southern highlands took on a rusty shade. To the unaided eyes, the Moon’s northern half (closest to the umbra) almost vanished into the background sky as mid-totality neared, making totality appear like a burning brand of the letter C.
By the way, on Oct. 25, a partial solar eclipse occured, favoring Europe, South and West Asia, and northeast Africa. A total lunar eclipse followed Nov. 7/8, which favored the Americas, north and east Europe, Asia, Australia, and part of Antarctica. If you made a curious observation, send it to sjomeara31@gmail.com.
