Imaging through a scope
A telescope opens up a whole range of fainter comets for imaging, not just those rare and spectacular naked-eye sights. At any one time, there can be hundreds of dim comets within reach of an amateur scope mounted with a high-quality camera. Although most are likely too faint to be worth capturing, often, there are several gracing the sky at once, and they make for excellent targets through small scopes.
Pretty much any telescope can be used to shoot comets. But observers tend to favor fast refractors, Newtonians, and Ritchey-Chrétiens for their wide, flat fields of view and fast f-ratios.
Although DSLRs will still produce good results, many observers opt to use dedicated astronomical CCD cameras, such as those manufactured by companies like SBIG and FLI. These cameras are certainly not cheap, but they do offer the highest image quality. Using dedicated CCD cameras requires the usual methods associated with deep-sky astrophotography, such as using dark frames and flat fields to fully calibrate the images before processing.
Planning your imaging session is especially important when using your telescope. Many comets reach their peak brightness when they are located low in the twilight sky, so time is often limited when it comes to capturing good data.
Quality planetarium software is essential to planning observations, especially for comets. Many software packages are available, such as TheSky, Starry Night, and Cartes du Ciel. Planetarium programs like these allow you to carefully plan out your observing session, helping you maximize your data and, therefore, the quality of your final image.
You’ll also need to update the program’s comet orbital elements using the Minor Planet Center’s ephemerides. (See the “Further Reading” sidebar on the next page.) These are databases that provide the calculated positions of celestial objects; this will ensure the positions of known comets are displayed accurately, as well as add any new comets as they are discovered. These programs also allow you to input your camera and telescope field of view to allow you to better plan out your composition by carefully positioning the comet on the camera sensor for optimal framing.
When imaging most comets through a telescope, you’ll immediately notice that your target moves with respect to the background star field. Some comets move across the sky much faster than others, but usually, any single exposure longer than four to five minutes will result in trailing of the comet itself in your image. The easy solution to this is to take several short exposures, such as five 60-second shots, and then stack them together. This will result in a clean and sharp comet, but it will also leave you with a trailed star field. Nonetheless, this method is the one employed by most telescopic comet observers.
If you want to avoid trails altogether, you can use a more complex image processing routine that combines two different master image stacks: one short-exposure stack showcasing trailless stars and another long-exposure stack that makes the comet really pop.
