Death by black hole in small galaxy?
A bright long-duration flare may be the first recorded event of a black hole destroying a star in a dwarf galaxy.
RELATED TOPICS: BLACK HOLES | DWARF GALAXIES
Dwarf galaxy in Abell 1795
A dwarf galaxy is located in the galaxy cluster Abell 1795.
X-ray: NASA/CXC/Univ. of Alabama/W.P.Maksym et al & NASA/CXC
A bright long-duration flare may be the first recorded event of a black hole destroying a star in a dwarf galaxy. The evidence comes from two independent studies using data from NASA’s Chandra X-ray Observatory and other telescopes.
As part of an ongoing search of Chandra’s archival data for events signaling the disruption of stars by massive black holes, astronomers found a prime candidate. Beginning in 1999, an unusually bright X-ray source had appeared in a dwarf galaxy and then faded until it was no longer detected after 2005.
“We can’t see the star being torn apart by the black hole, but we can track what happens to the star’s remains and compare it with other similar events,” said Peter Maksym of the University of Alabama in Tuscaloosa. “This one fits the profile of ‘death by a black hole.’”
Scientists predict that a star that wanders too close to a giant or supermassive black hole could be ripped apart by extreme tidal forces. As the stellar debris falls toward the black hole, it would produce intense X-ray radiation as it is heated to millions of degrees. The X-rays would diminish in a characteristic manner as the hot gas spiraled inward.
In the past few years, Chandra and other astronomical satellites have identified several suspected cases of a supermassive black hole ripping apart a nearby star. This newly discovered episode of cosmic, black-hole-induced violence is different because it has been associated with a much smaller galaxy than these other cases.
The so-called dwarf galaxy is located in the galaxy cluster Abell 1795, about 800 million light-years from Earth. It contains about 700 million stars, far less than a typical galaxy like the Milky Way, which has between 200 and 400 billion stars. Moreover, the black hole in this dwarf galaxy may be only a few hundred thousand times as massive as the Sun, making it 10 times less massive than the galaxy’s supermassive black hole and placing it in what astronomers call an “intermediate-mass black hole” category.
“Scientists have been searching for these intermediate-mass black holes for decades,” said Davide Donato of NASA’s Goddard Space Flight Center (GSFC) in Greenbelt, Maryland. “We have lots of evidence for small black holes and very big ones, but these medium-sized ones have been tough to pin down.”
The evidence for a star being ripped apart by the dwarf galaxy’s black hole came from combing through Chandra data that had been taken over several years. Because Abell 1795 is a target that Chandra observes regularly to help calibrate its instruments, the researchers had access to an unusually large reservoir of data on this object.
“We are very lucky that we had so much data on Abell 1795 over such a long period of time,” said Brad Cenko, also of GSFC. “Without that, we could never have uncovered this special event.”
The dwarf galaxy’s location in a galaxy cluster also makes it a potential victim of another type of cosmic violence. Because galaxy clusters are crowded with galaxies, it’s possible that a large number of stars have been pulled away from the dwarf galaxy by gravitational interactions with another galaxy in the past, a process called tidal stripping.
“It looks like the stars in this galaxy not only need to worry about the black hole in the center,” said Melville Ulmer of Northwestern University in Evanston, Illinois. “They might also be stolen away on the outside by gravity from a passing galaxy.”
Astronomers believe that intermediate-mass black holes may be the “seeds” that ultimately formed the supermassive black holes in the centers of galaxies like the Milky Way. Finding additional nearby examples should teach us about how these primordial galaxies from the early universe grew and evolved over cosmic time.
Some of the additional clues to this star attack came from NASA’s Extreme Ultraviolet Explorer that picked up a bright ultraviolet source in 1998, which could have marked a time just after the star was initially torn apart. A flare in X-rays may have also been detected with ESA’s XMM-Newton satellite in 2000.
exoticobjectspromo
